Simplifying mesh objects
Command
Path
Simplify Mesh
Modify
The Simplify Mesh command simplifies mesh objects by reducing the number of polygon faces. More simplification reduces the quality of the shape, but also reduces file size and processing time. Multiple mesh objects can be simplified simultaneously.
This command can enhance performance when working with complex 3D objects.
To simplify one or more meshes:
Select the mesh object to simplify. Individual meshes can be simplified, as well as meshes contained within other objects, such as groups, symbols, or IFC entities.
Select the command.
The Simplify Mesh dialog box opens.
Parameter
Description
Quality
Drag the slider to set the quality of the mesh object; lower quality results in greater simplification and faster processing
Original number of faces
Displays the original number of faces in the selected meshes
Simplified number of faces
When Preview is clicked, displays the number of faces in the simplified meshes
Preview
Dynamically previews the simplified mesh object
Convertir en malla
Edición de objetos de malla
